I just remembered that someone else who couldn't get system status from the BPCM was able to get cell voltage from the EVCM system status readings.
You shouldn't have to view it on the spot, since the app's default setting is to auto-save them to view later.
___
Tested device: Electric Vehicle Control Unit (EVCU)
___
2024/04/24 16:41:33.627
DEVICE INFO:
Fiat drawing number:
VMI: 3C3
VDS: CFFGE9
VIS: ET175975
Hardware number: �����������
Hardware version: FF
Software number: 05192357AC
Software version: 0300
Homologation number:
ISO code: 2020202020
SINCOM:
Factory:
Serial No:
VIN - Original: 3C3CFFGE9ET175975
Application Data Fingerprint: 01 33 34 35 35 34 20 20 20 20 16 07 21
ECU Part Number: 05192356AL
Boot Software Identification Supplier: Continental
Number of modules: 01
Module ID: 42
Version Module ID: 05192357AC
Application Software Supplier: Continental
Module ID: 42
Version Module ID: 16V2_3p0b0
Application Data Identification Supplier: Continental
Module ID: 42
Version Module ID: Cal 012116
Boot Software Fingerprint: 01 20 00 20 00 20 00 20 00 20 00 20 00
Application Software Fingerprint: 01 33 34 35 35 34 20 20 20 20 16 07 21
ECU Spare Part Number:
Ecu Serial Number:
ECU Serial Number Data Identifier: T
ECU Serial Number Supplier Option: 00
ECU Serial Number Component Code: EM
ECU Serial Number Day of Year: 306
ECU Serial Number Calendar Year: 3
ECU Serial Number Sequence Number: YN15E
Active Diagnostic Status Of ECU: Running in Application mode
Gateway: No
ECU Variant ID: 01
ECU Version ID: 03
__
___
Reading faults for: Electric Vehicle Control Unit (EVCU)
___
Faults reported:
2024/04/24 16:41:42.557
Faults found.
P0562
U0111
U1200
P0607
P058A
P060C
Error code: P0562
System Voltage Low
Last test completed positively
Error intermittent
Failure warning lamp 'ON': Not requested
___
'Clear fault codes' command sent
Immobilizer Status:
ECU status: Coded
Cranking Enabled: Disabled
Universal code status: Not received / ECU coded
Fast restart Function: Not active
Incorrect Key Code: Not present
Unknown Key Code: Not present
No Code Received or Timeout: Not present
Odometer: 56946.00 km
Odometer reading: 35307 miles
Ignition Status: Run
Ignition Switch: On
Estimated Range: 254 km
Vehicle speed: 0.00 km/h
Accelerator pedal position: 0.00 %
Battery voltage: 12.20 V
Battery Sense Voltage: 12.20 V
5V Out 1 Voltage Sense: 5.00 V
5V Out 2 Voltage Sense: 4.99 V
EV Service Light: EV Service Light
Accelerator pedal sensor 1: 1.01 V
Accelerator pedal sensor 2: 0.50 V
Brake switch normally open: Open
Brake switch normally closed: Closed
Parking Brake Status: Off
Regen Braking Status:
Regen event with current to the HV battery > threshold value: No
Regen event with current to the HV battery: No
Regen event due to braking: No
Regen capacity available from Powertrain: No
Regen event due to vehicle speed coast down: No
Regen not possible due to an active vehicle fault: No
Regen not allowed by PIM (No fault): Yes
HVIL Sense PWM Input State: Off
A/C Pressure Sensor: 0.97 V
Inverter Coolant Temperature Sensor: 4.25 V
Quadrature Sensor Signal 1: 155
Quadrature Sensor Signal 2: 155
PRND Park Switch:
PRND Park Low Side Switch: 1.78 V
PRND Park High Side Switch: 3.37 V
Park switch state: Not pressed
PRND Reverse Switch:
PRND Reverse Low Side Switch: 1.77 V
PRND Reverse High Side Switch: 3.37 V
Reverse Switch State: Not pressed
PRND Neutral Switch:
PRND Neutral Low Side Switch: 1.77 V
PRND Neutral High Side Switch: 3.37 V
Neutral Switch State: Not pressed
PRND Drive Switch:
PRND Drive Low Side Switch: 1.78 V
PRND Drive High Side Switch: 3.37 V
Drive switch state: Not pressed
PRND Position: Park
Power Electronics Cooling Pump Relay: On
PRND Park Jewel Feedback:
PRND Park Jewel Status: Not defined
PRND Reverse Jewel Feedback:
PRND Reverse Jewel Status: Off
PRND Neutral Jewel Feedback:
PRND Neutral Jewel Status: Off
PRND Drive Jewel Feedback:
PRND Drive Jewel Status: Off
ePRND Jewel Dimming: 100.00 %
Propulsion Ready Status:
Propulsion System Ready Status: not ready
Contactor Status:
Contactor Status: Not defined
Master EV Wake-Up: Set
Impact Event: No
Motor Resolver Offset Learn Timer for In-Plant: 900 sec
Motor Resolver Offset Learning Status Flag: No
Switch Input Filtered State:
Ignition Run/Start Switch Filtered Switch State: Off
Ignition Start Switch Filtered Switch State: On
Brake Switch 2 Filtered Switch State: Off
Ignition Off Run Start Switch Filtered Switch State: Off
Park Neutral Switch Filtered Switch State: On
Brake Switch Filtered Switch State: On
ePRND Park switch state: On
ePRND Reverse switch state: Off
ePRND Neutral switch state: Off
ePRND Drive switch state: Off
EAC Compressor Speed: 0 rpm
EAC/Rad Fan Relay State:
EAC/Rad Fan Relay State: Not defined
A/C Refrigerant Pressure: 6.00 bar
Ambient Air Temperature: 21.50 Deg.C
Bussed Inputs (BPCM):
Battery Coolant Pump Duty Cycle: 0 %
Battery Coolant Pump rpm: 6120 rpm
Battery Coolant Pump temperature: 205 Deg.C
Battery Coolant Pump Voltage: 25.50
Battery Coolant Pump Current: 51.00 A
Battery radiator coolant temperature: 25.00 Deg.C
Battery inlet coolant temperature: 25 Deg.C
Battery outlet coolant temperature: 25 Deg.C
Battery Coolant Heater Duty Cycle: 0 %
Battery Pack Voltage: 0 V
Battery Pack Current: 0.00 A
Battery Coolant Pump Error Present: pump off
Passive Cooling Valve: Unpowered
Chiller Heater Valve: Unpowered
Power Electronics Coolant Pump relay: Not defined
Refrigerant Shutoff Valve: Off
Intelligent Battery Sensor Current: -8.92 A
Power Electronics Coolant Temperature: 20 Deg.C
PIM heat plate temperature: 213 Deg.C
PIM output current: 254 A
PIM status: Off
PIM DC Link Voltage: 0 V
PIM State: Not defined
Power Electronics Coolant Pump Duty Cycle: 69 %
Radiator Fan Duty Cycle: 10 %
Intelligent Battery Sensor(IBS) Data 1:
Intelligent Battery Sensor(IBS) Data 1: 12.21 V
Intelligent Battery Sensor Current: -743 A
Intelligent Battery Sensor Temperature: 20 Deg.C
Intelligent Battery Sensor Current Range Sensor Setting: Range I200
Intelligent Battery Sensor(IBS) Data 2:
Intelligent Battery Sensor State of Charge: 67 %
Intelligent Battery Sensor SOC Accuracy Status: Error < 10%
GSM Motor Enable: No
GSM Motor PWM #1: 51.60 %
GSM Motor PWM #2: 51.20 %
Driver door: Open
EAC HV Current: 0.00 A
EAC HV Input: 0 V
EAC Operational Status: Normal Operation
EAC Power: 0 W
Inverter Coolant Temperature: 20 Deg.C
Hybrid System State: Command Contactors Close
Charging System State: Wait For Charge Ready
Power Limiting Mode:
Distance Traveled with Light ON: 56805 km
Estimated Range: 255 km
High Voltage Battery State of Charge: 50.20 %
Ambient Air Temperature: 21 Deg.C
Motor Temperature: 213 Deg.C
Inverter Temp: 213 Deg.C
Maximum Battery Module Temperature: 25 Deg.C
Minimum Battery Module Temperature: 25 Deg.C
Maximum Battery Cell Voltage: 3.70 V
Minimum Battery Cell Voltage: 3.70 V
EVCU Wake-Up: Off
EVCU Wakeup Reason: Key in Ignition
HV Battery Average Cell Voltage: 3.71 V
HV Battery Commanded Contactor Status: Closed
HV Battery Coolant Valve 1 Request: Open
HV Battery Coolant Valve 2 Request: Open
HV Battery Current: 0.00 A
HV Battery Max Cell Voltage: 3.71 V
HV Battery Min Cell Voltage: 3.71 V
HV Battery Module Temp Average: 25 Deg.C
HV Battery Module Temp Max: 25 Deg.C
HV Battery Module Temp Min: 25 Deg.C
HV Battery Voltage: 0 V
HV Battery Cell Balancing Status: Not Balancing
HV Interlock Status: Failed
HV Isolation Status: Not Sourced
Battery Coolant Pump Requested PWM: 0 %
Battery Heater Request: 3 %
Charging Current Request: 0.00 A
Charging Enabled: No
Charging Voltage Request: 399 V
EVCU Shutdown Command: No
EVSE Contactor State: Open
OBCM Charger Ready: Off
HV Batt Ready for Charge: not ready
Actual Torque: 0 NM
Available Motor Torque: 0 NM
Available Regen Torque: 0 NM
Commanded Torque: 0 NM
DC Current: 0 A
Electric Motor Speed: 0 1/min
EVCU Requested HV Current: 14.05 A
Park Pawl Motor Current: 0.00 A
Park Pawl PWM Feedback 1: 51.60 %
Park Pawl PWM Feedback 2: 50.80 %
Estimated Regen Torque: 0 NM
Regen Torque Request: 0 NM
Charge Request: Stop Charge
Charging Status: not ready
Evaporator Temperature Actual: 87.50 Deg.C
Evaporator Temperature Target: 60.00 Deg.C
HV Battery Thermal Management Status: pump off
S/C Switch Status:
S/C On/Off Switch: Off
S/C Resume Switch: Off
S/C Decel Switch: Off
S/C Accel Switch: Off
Speed Control (S/C) Working Status:
Cruise control status: Not active
Cruise Disabled: Cruise Not Engaged
S/C Set Speed: 0.00 km/h
S/C Set Switch: Not pressed
S/C Status: Off
S/C Status-EVCU: S/C Not Engaged
IP EE REG FLAGS 1:
IP EE BATTERY TEST NOT COMPLETED: Set
IP EE BATTERY CHARGING FAILED: Set
In-Field Mode: Set
REM Mode: REM Disabled
__
___
___
2024/04/24 16:43:37.424
DEVICE INFO:
VMI: 3C3
VDS: CFFGE9
VIS: ET175975
SINCOM:
Factory:
Serial No:
Module ID: 42
Module ID: 42
Module ID: 42
Ecu Serial Number:
Gateway: No
ECU Variant ID: 01
ECU Version ID: 03
__
___
___
Faults reported:
2024/04/24 16:43:48.948
Faults found.
P058A
P060C
___
___
Faults reported:
2024/04/24 16:43:52.774
Faults found.
P058A
P060C
___
___
___
Faults reported:
2024/04/25 19:54:26.507
Faults found.
P0562
U0111
U1200
P0607
P058A
P060C
___
___
Faults reported:
2024/04/25 19:54:50.275
Faults found.
P0562
U0111
U1200
P0607
P058A
P060C
___
