Hello,
I replaced a faulty PCM in a Fiat 500 and now the engine computer has a P0513 (Incorrect Immobilizer Key).
In the past I've done the same to a Dodge Dart, used alfaobd software to write the vin to the new PCM, ran a proxy alignment and the car started right up. I'm guessing the proxy alignment is the issue in this fiat, as I'm using the suggested yellow adapter to talk to the BCM, but it's only running a proxy on 4 modules and skipping the others including PCM (probably because of the adapter). Would appreciate any guidance here, hopefully I'm just missing something obvious. Very few threads talking about PCM swaps on this car
Extra info:
Thanks!
update: swapped the eeprom from the original pcm to the new engine computer. Working
Extra info:
- Installed new PCM
- Reset ECU
- Wrote VIN
- Cam crank relearn
- Proxy Alignment completes successfully (BMC, Radio, Instrument panel, Climate control)
Thanks!
