Will racks for 2014 fit 2012? Or what national company would have the one I need?
Set up looks great. What base rack is that?etrailer has a YAKIMA set. This is what my Thule looks like today with an INNO cargo box and a YAKIMA bike rack. I put the stock wheels back on and will change the front to the EU style
All Thule, Thule Aero Bars, Thule mounts. If you noticed, I moved the mounting point for the rack to be more centered.Set up looks great. What base rack is that?
Can I ask you what the dimensions of your Box are? They fits so nicely and most I encountered are 148cm long, which i guess is longer than yours?etrailer has a YAKIMA set. This is what my Thule looks like today with an INNO cargo box and a YAKIMA bike rack. I put the stock wheels back on and will change the front to the EU style
It looks absolutely amazing! Thanks so much for the dimensions, makes sense. Think I will go with the Arjes 133cm (which is pretty equivelent to the INNO.
Thanks for sharing. It doesnt say the width of the Thule bars. i know they are availabe in a wide range. Can you tell anything about that?I have the PDF for the Thule fit kit.
Aah that suprises me! I checked the pdf en on the second page it outlines the placement of the bars and say 996 cm. So I got confused.Both of my bars are 47 inches. Did you see the PDF I sent on the fit kit For the other measurements? I hope this helps.
Just measures at 47"It looks absolutely amazing! Thanks so much for the dimensions, makes sense. Think I will go with the Arjes 133cm (which is pretty equivelent to the INNO.
Final question, what is the with/size of your aerobars?
The roofrack dealer I contacted said he ships them with 120 cm / 47 inch. However, this is wider than the cars original roof and on the picture yours looks closer to 105 cm / 41 inch.
Kind regards, Robert
I only rely on Thule - above picture from RackOutfitters looks pretty much like what I use: Thule Wingbars, Thule 774 SRA (Short Roof Adapter), Thule Rapid 754 feets and either Thule Rapid Kit 1856 for glass roof or 1611 for steel roof.
Works perfect - I'm used to hauling kayaks, bikes, ski boxes, recumbents etc - have brought both kayaks and recumbents home from Amsterdam to Copenhagen, Denmark over time on different cars.
This set-up is bomb proof - fairly easy to install and sits with a very firm grip. I'd trust it as much as I trust Thule on any other car I've had.
Forget about rigs where You have to dig the grip-plate in under the rubber of the rear side windows; cumbersome and You still have connection rods between bars - and I've seen user reports telling that it's easy to scratch your car during mounting(
