Hello! Im not sure what exactly the problem is. I've done some snooping on google, and a lot of it leads me to the 1.4L Dart. I know they are pretty much the same engine but I wanted some insight from you guys.
The mods I have done to my car
DIY Ram intake (Kept the stock arm, placed a cone filter on the end and the air box blows on it) I've had this for a few hundred miles
RRM Ultimate Basic Stage 3 Tune (Just installed and just did the 80 mile break in - and then I got a check engine light)
I was able to connect the RRM Tune to my MAP sensor, and my Boost sensor like it stated was required. I drove around the city driving "Spirited" going through all the gears and getting boost. Soon after the 80 mile mark, I got a check engine light and my turbo wouldn't spool past 6PSI. A quick restart allowed the turbo to spool freely however the check engine light is still there. I took it to Autozone to pull the code and it said "p0299-Turbo Charger/SuperCharger under boost condition - Permanent".
Another weird thing I noticed a couple times that the Turbo would spool up and then feel like it cut out quickly, and respool back up again. No weird sounds or anything. Ideas? - Also important to note that my 'Ghetto' Ram intake did cause my turbo to go into limp mode before, but never through up an engine light. After doing a better job securing the arm to keep it from moving it seemed to resolve the issue until now. Im also wondering if I should use a bigger cone. The one I got was from a bike shop and can fit in the palm of your hand (http://imgur.com/Sw7dVKm)
