Hello guys its a pleasure to be here with all of you, my quotation is i have the original fiat charger which is 12 Amp (is that correct!!) 8 hours charging time .. i need to know if there any faster charger and is that safe on it !
There's nothing that gives any indication that this adapter above delivers 240V to the 5-15 socket. It's not really a step down. A 14-50 has two 120V lines, a ground, and a neutral. The two 120V lines together form 240V, while either 120V and a neutral gives 120V. So this adapter likely does the latter without any real step down.Here are the two adapters, the plug on my charger is standard 3 prong 5-15, with 14 gauge cable. The charger apparently draws a max 16A. My charger says it is good for 110V to 250V.
This is the first adapter, but it apparently steps it down to 120, so I wouldn't be gaining anything, would I?
AC WORKS® [AD1430520] Adapter NEMA 14-30P 30A Dryer Outlet - Household 15/20A 125V T-Blade Connector
This AC WORKS® brand product [AD1430520] is a super durable and compact adapter. It is a NEMA 14-30P to NEMA 5-15/20R. The adapter is a NEMA 14-30P, 30 Amp, 125/250 Volt, 4-prong dryer male plug to NEMA 5-15/20R, 15/20 Amp, T-blade female connector. The pins and terminals are nickel-plated...acworks.com
That's correct. The OEM EVSE is a worldwide unit. It operates at both 120V and 240V. I've personally tested this and it works fine.This next one says you can plug in the OEM charger, and get Level to as you said, who knew that was even possible. The manual that comes with the charger says 120V, nothing about 220. It has a maximum of 12 amps. I cant tell the regular 3 prong plugs into it, but it must if it is for OEM charger, right?
12 amps. The EVSE doesn't change the amount of current that it offers to the car.![]()
Level 2 Upgrade Adapter 220 240V for Fiat 500e 2017, 2018, 2019
Do you have a 2016, 2017, 2018, or 2019 Fiat 500e?If you have access to a 220V / 240V outlet, you can use this Level 2 Upgrade adapter, along with the charge cord (EVSE) that came with your car, to effectively DOUBLE to voltage and possibly TRIPLE your charge rate (if you're stuck at 8A...ideafab.shop
To get the maximum level 2 4 charge, it takes 240 volts, but how many Amps?
Maximum is 30 amps at 240V giving 6.6 kW of power.What is the maximum Amps the car will take? 28 or 30 or more?
No problem.thanks Michael
This locking cover allows for the EVSE to be plugged in while having the box locked for example.
Thanks. That's exactly what I need. We charge in the driveway off a 12/3 extension cord. I'm having an outlet installed outside.
ga2500ev
No problem. The OEM Fiat charger limits itself to drawing a maximum of 3.3kW (at 13.75 amps). You can plug it into a 50 amp circuit and it will still pull the same 3.3kW. Think of how you can run a vacuum cleaner from a 120V receptacle and your phone charger doesn't burn out when you plug it into the same receptacle.so how dangerous is it having the oem Fiat charger plugged into the 30 amp circuit?
I don’t think this is correct. At 120v I’m fairly certain 12a is the limit. At 240v with a modified evse the car charges slightly faster than 2x on 120, so my guess is that it might do 16a at most. If it were capable of 30a no one would be buying any 3rd party evses, and it would have fried my 20a circuit.The Fiat EVSE can charge at 30 amps no problem. It's designed for both 120v and 240v, except the US version comes with 120v plug as standard.
