Hello guys its a pleasure to be here with all of you, my quotation is i have the original fiat charger which is 12 Amp (is that correct!!) 8 hours charging time .. i need to know if there any faster charger and is that safe on it !
No problem. The OEM Fiat charger limits itself to drawing a maximum of 3.3kW (at 13.75 amps). You can plug it into a 50 amp circuit and it will still pull the same 3.3kW. Think of how you can run a vacuum cleaner from a 120V receptacle and your phone charger doesn't burn out when you plug it into the same receptacle.so how dangerous is it having the oem Fiat charger plugged into the 30 amp circuit?
Here is the picture of the display, interested to see what it shows when I get the adapter to plug it into the 240.
This locking cover allows for the EVSE to be plugged in while having the box locked for example.
Thanks. That's exactly what I need. We charge in the driveway off a 12/3 extension cord. I'm having an outlet installed outside.
ga2500ev
It was assuming a 240V circuit, and the 3.3kW charging rate someone mentioned earlier. 240V will be twice the charging rate of a 120V circuit. You measured 1.8 kW, and 2x would be 3.6 kW. That is close enough to 3.3 kW and the actual number will vary a bit depending on realtime circumstances.I would like to know where you got the 13.75 Amp figure for the OEM charger, thanks
I'm not Fiat, I've got big bones. (and a nice personality)rucallingmefiat,
love your user name!
I don’t think this is correct. At 120v I’m fairly certain 12a is the limit. At 240v with a modified evse the car charges slightly faster than 2x on 120, so my guess is that it might do 16a at most. If it were capable of 30a no one would be buying any 3rd party evses, and it would have fried my 20a circuit.The Fiat EVSE can charge at 30 amps no problem. It's designed for both 120v and 240v, except the US version comes with 120v plug as standard.
More accurately, you can plug it into a 30 amp circuit no problem. It will draw about 14 amps from the circuit. It won't "charge at 30 amps".The Fiat EVSE can charge at 30 amps no problem.
I built my own since I was just testing and it wasn't going to be permanent. I have a 10-30 dryer outlet. I also happened upon some 6-20 appliance extension cords on clearance that I'm using to bring power in from a generator. So I ended up with splicing the female end of the 6-20 to the dryer 10-30 and connecting the male end of the 6-20 to a standard 5-15 socket placed in a big box hardware blue electrical box. Took about a half hour to throw together.thanks, I have learned more than I thought I would ever need to!
What connector do you have from the OEM charger to your 14-30 dryer outlet?
thanks Michael
