Hello guys its a pleasure to be here with all of you, my quotation is i have the original fiat charger which is 12 Amp (is that correct!!) 8 hours charging time .. i need to know if there any faster charger and is that safe on it !
Of course you can. It's 16A at 120V that won't pull full power.I am not even sure if you can do 240v 16amps.
Typically empty to full at 6.6 kW (240V/30A) is just about 4 hours. Everything else is generally proportional to that. So 240V/16A is 3.84 kW. Nominally 6.6 kW for 4 hours is 26.4 kWh. 26.4 kWh/3.84 kW give 6.875 hours. So the 16 A charger will take about 7 hours from empty to full.Ok so here is the bottom line, how much faster will it charge at 240 volts and 30 amps, vs 240 volts and 16 amps?
That will make my decision, if anyone knows, thanks.
Michael
Lawyers. If it has 5-15 plug on it, the label has to state that it can only be run at 120V. If anyone decides to violate that, even it if works fine, which it does, then FCA is off the hook if anything happens.That is nuts! Why would they not have in the manual that it can run 240V? 30 amps, really? How do you know that?
I didnt need to buy the other one. Too bad.
Not 30 amps. You're confusing the power at the outlet with the power to/through the device. Power at an outlet should always be read as "up to" the maximum amps. So the 14-30 dryer outlet is "up to" 30 amps. If you plug in something that draws less current, then the socket will supply only the requested current. For example an LED light bulb may only draw 15W, which 0.125A at 120V. No one thinks anything of plugging one into a 15A socket.Ok, so will the standard 3 prong plug and wiring on it handle 30 Amps? The wiring on it says 16AWG and 18AWG, which seems pretty strange to me.
thanks Michael
[QUOTE = "rucallingmefiat, publicación: 1295786, miembro: 110288"]
El Fiat EVSE puede cargarse a 30 amperios sin problema. Está diseñado para 120v y 240v, excepto que la versión para EE. UU. Viene con un enchufe de 120v como estándar.
[/CITAR]
Good afternoon. I'm confused. Can you use the original US Fiat oem charger that says only 120 in a 220 socket?
Seems reasonable, but one of these might still work on 120v:Typically I will only put 20-30 miles on the 500, but there will be occasions I'll need the full 80-100 miles and I don't want to get into a bind where I need to wait 20 hours to get fully recharged again. Faster recharging will make the car just that much more flexible, enjoyable, and reduce range anxiety.
I suggest belaying that order just for a moment.Great, thank you! I'll order and report back on how it goes once I try it out.
I have 2013 Fiat 500e, and 240 nema 14-50 plug in my garage. Can I use Level 2 Upgrade Adapter from Ideafab to get level 2 charger for my Fiat. It said 2017 model but not 2013 model. Wonder my original Fiat EVSE charger can plug to 240V outlet.There's nothing that gives any indication that this adapter above delivers 240V to the 5-15 socket. It's not really a step down. A 14-50 has two 120V lines, a ground, and a neutral. The two 120V lines together form 240V, while either 120V and a neutral gives 120V. So this adapter likely does the latter without any real step down.
That's correct. The OEM EVSE is a worldwide unit. It operates at both 120V and 240V. I've personally tested this and it works fine.
12 amps. The EVSE doesn't change the amount of current that it offers to the car.
Maximum is 30 amps at 240V giving 6.6 kW of power.
No problem.
ga2500ev
The 2013 OEM wil work fine. I wouldn't cut off the plug because it has a temperature sensor built into it.I have 2013 Fiat 500e, and 240 nema 14-50 plug in my garage. Can I use Level 2 Upgrade Adapter from Ideafab to get level 2 charger for my Fiat. It said 2017 model but not 2013 model. Wonder my original Fiat EVSE charger can plug to 240V outlet.
Also my Fiat OEM charger plug kinda burn, can I cut the plug and replace with 14-50 nema plug? Thanks
my plug burn like this. Should i cut and replace with14-50 plug? Or just buy a new evse level 2 chargerThe 2013 OEM wil work fine. I wouldn't cut off the plug because it has a temperature sensor built into it.
ga2500ev
